Creating linetype style in Intellicad (looking for linetype library)
Durgle
(@durgle)
I am a new intellicad user and I am setting up everything for F2F for my new employer.?ÿ I think I have figured most of it out, but I am having issues finding the correct linetypes for standard land surveying.?ÿ When I am in the field code library it looks like standard utility lines are available ( --E--, etc).?ÿ Yet when I process it the line comes in as individual entities, like it was exploded.?ÿ Each - and E are their own block.?ÿ I am not sure why this is.?ÿ And yet I cant find any information anywhere about how to make a linetype.?ÿ I do not know the syntex for creating a line, nor the Intellicad have a "Make Linetype" command (this is the first AutoCAD command that I have not been able to find in Intellicad).?ÿ So I am asking if anyone knows how to do this in Intellicad, or better yet, does anyone have a standard surveying Linetype Library I could use??ÿ Intellicad uses all the same file extensions, so it will read any AutoCAD Linetype library.?ÿ Thanks
-JS
Posted : July 25, 2019 10:10 am
In Texas we have used a specific linetype for Headright boundaries from like day one.
It is a line that has 3 short dash to every several inches of unbroken line.
My son used a utility in Carlson program to create me that linetype.
From what he said, it was possible to create most any type of line that your keyboard can create graphics.
0.02
Posted : July 25, 2019 2:34 pm
blitzkriegbob
(@blitzkriegbob)
A few points:
  • Intellicad by itself won't do F2F, so it would be helpful to know what third party software you are using.?ÿ I'm assuming it's Carlson.
  • I don't think that you will find a "standard" linetype file for surveying.?ÿ Having started my career in Houston, I hate the use of letters within linetypes, but can still tell you when looking at a City of Houston drawing what type of utility a line is by the number of dashes and the spacing of the dashes.
  • Intellicad uses a .lin file for linetypes, the same as AutoCAD.?ÿ Do a search for *.lin and you will find a file.
  • It's not that hard to write linetype definitions. If need be, I can walk you through it.?ÿ If you are using Carlson, then you won't need to do this, but it's always nice to learn.
Posted : July 26, 2019 6:10 am
