A few commands I noticed missing on OEM version, I upgraded from AutoCAD 2002 to the OEM 2016 last year and thought the commands were abandoned but later loaded Civil 3d and found the commands still there.
Lengthen, been using Extender
Rename, I needed this one day to rename a nested block in an old drawing.
Filter, been using Qselect
Just wondering if anyone noticed other commands missing. I know the Arc command works different, but didn't know if that was changed by Carlson.
The OEM version does have some of the basic, AutoCAD functions removed. Carlson has, for the most part, added them under other menus.
One that I really miss is the plain old divide command. I discovered it one time, but did not make myself a note as to where it was.
The removal of basic 2D line command is a pain.
Before when drawing a polyline, I could scroll back on the previously entered data. It was useful when I was continuing a line. I just edited the distance. Also ctrl D doesn't switch the curser location from polar to rectangular anymore. However, I don't know if that has anything to do the OEM version.
If I remember right, the rename command were on the Intellicad version.
