Carlson Survey 2014 w/ Intellicad Field to Finish Issue
1 Users
(@lugeyser)
I'm having a problem with Field to Finish that is all the sudden. I have programed my field to finish file to create no separate point attribute layers for any points, although I do have it creating distinct point layers.
When I generally run it, when prompted for how do you want to handle multiple codes, I always pick, do not separate.
For some reason now, it is creating multiple points on almost everything. One goes on the appropriate layer as programmed by .fld file, the other goes on whatever the current layer is.
Can someone tell me what setting I inadvertently changed? I'm thinking it may have happened when I installed the patch. Another odd thing is that all my point layers are color white normally, but now some are coming in yellow and magenta. Again, I've been using this setup for 2.5yrs roughly (previously Carlson 11) and no issues until lately.
Thanks
Posted : September 17, 2014 7:51 pm
