Carlson- Sections
(@guest)
Hello, I've got Carlson civil/survey 2012 and have a question.
I've got some cross sections I've generated from a surface model. I'd like to add the right of way and fences to the sections.
Can this be done? In the past I have manually added this information by scaling and sketching. Seems like there would be a routine to do this.
I would even think that it would sample a point specifically where your right of way crosses the section.
Any suggestions?
Posted : October 25, 2011 1:44 pm
(@sir-veysalot)
I understand your question but how would it know what elevation to plot at? I have tried the same thing.
Posted : October 25, 2011 1:52 pm
(@guest)
Well it could work several ways. First it could just be an offset label. Second it could sample a point from the tin at the r/w line as well at all of the triangle edges.
I think I'm getting close. There is a "Section Points from Right of way" routine, just have not gotten all the way through it yet.
Posted : October 25, 2011 2:06 pm
(@derek-g-graham-ols-olip)
Gary Rosen, Carlson's Regional Sales Director for New England and Canada gave a pitch at our Drainage Conference last week and I think that he showed such a facility was possible.
You might try grosen@carlsonsw.com
Cheers
Derek
Posted : October 25, 2011 3:01 pm
(@guest)
I would think it would be fairly easy.
So far I have been able to convert my RW lines to 3D polylines by draping them over the TIN, then creating a .sct file using the "section points from right of way" routine. It then creates a section file with the offset and elevation of the right of way. These can be plotted with the existing ground sections. However the description ends up being POINT-ROW-R_
Not really convient for labeling. It does plot a circle where the R/W is....I guess that is better than nothing. I'd like a vertical line with a R/W label.
This would not work very well if the r/w lines were beyond the TIN. You might have to assign a dummy elevation to the r/w lines.
If there is a better way, someone please chime in.
Posted : October 25, 2011 3:17 pm
(@guest)
Ok, that is what I thought. It IS much easier. The r/w lines do not have to be 3D polylines, you just have to have label RW checked on in the draw section dialog box.
The description is a special description that allows the program to know where to draw the vertical line.
Step 1 create your existing sections
step 2 either edit the sections to include the special description at the proper offset, or run the Section Points from Right of Way routine to create a special r/w section file.
step 3 include the special r/w section file when you are plotting the sections. Be sure and have "label rw" checked on.
Posted : October 25, 2011 3:27 pm
