I have multiple station equations in my alignment. I tried to use station equation interface that is available under centerline/input edit centerline file pull down menu, but each time I enter new equation, it applies this (most recently entered) to the whole alignment ignoring previous equations which results in incorrect stations. I tried number of things with no luck. Any help will be greatly appreciated!
Cheers
Are the station equations in the order that they occur? It's just a guess because I haven't used Carlson in a few years but that is a problem with Civil 3D. They have to be listed in the order in which they occur or it does some goofy things with your stationing.
hijack warning
Back in 69' I worked on a road project that had a 1.00 foot Elevation Equation at one of the Bench Marks. That screwed a few folks up!
Bench mark was close to 10,000 NGVD29 near the top of Elizabeth Ridge in the Uinta Mountains.
ssorcbor
Thanks for the reply.
Yes.
I also tried inserting the equations at the time of creating particular elements where equation applies.. didn't work neither..
