Anybody else having issues processing raw data? Software stops completely after clicking on process and picking the method of process.
Also it freezes if I try to list points.
This problem only occurs on one computer. File works on the other computer that's running 2010.
Thanks
I do not know of a way to copy objects to new layers and retain their properties unless that have all been set to something that is not "by Layer". If tons of layers does not warry you and you are using view ports, could you prefix the layers from each drawing to make them identifiable? You can easily add that using the rename command.
Try posting this on the Carlson web site Discussion Group. Someone there may have the answer. If not, contact Carlson Support via the link on the wed site. They are usually pretty quick in responding to support emails.
But to try to answer your question, no, we have not had this problem on our set ups.
It may be a bad load of the software. Check with Carlson and if they cannot find the problem, try reloading the software. Better yet download the latest version from the web site and you should get ALL of the bug fixes that they have come up with.
I found out that it's a dual monitor issue. The report viewer was hidden somewhere (but not in view or under anything) There is a patch for this very problem.
Whoops, wrong post.
