Block Reference issue
(@mapman)
Working with an imported DWG that has all of the text as a Block Reference. The typeset is way too large and cannot be reduced - locked. Other than Exploding it, is there a better way to convert to a style all of the Block references to alter the size etc.? Tried using scale. Doesn't work.
What drawing mode is best to work in - Model or sheet?
Thanks.
Posted : September 18, 2014 1:48 pm
(@davidgstoll)
Mapman,
What do you have set for INSUNITS in your System Variables?
Dave
Posted : September 18, 2014 3:19 pm
(@mapman)
Thanks for the reply. I left work for the day and will check it tomorrow. Sorry I don't have an answer.
I'm thinking of going for Carlson at this point anyway. Civil 3D is making my head hurt. 😉
I exported the drawing from an old Foresight.pro job to a DWG and wanted to see how much pain was involved in getting it to open. It doesn't look terrible, just the typeset is huge.
Posted : September 18, 2014 4:33 pm
 vern
(@vern)
select the block and right click
choose edit block
manipulate the text size in the block editor
_bclose is the command to escape from the block editor.
I recently discovered the beauty of using blocks for drawing record plats in their original basis of bearing (BOB) then convert to a block. Then you can align the block to your own BOB and the bearings of record will remain.
Posted : September 18, 2014 5:24 pm
