AMD Processors
(@jimmy-cleveland)
Does anyone have any comments regarding AMD processors for CAD/surveying applications?
I am looking at laptops, and I was wondering if the AMD processors were as good as the intel processors.
Thanks in advance
Posted : January 20, 2014 6:38 pm
Wendell
(@wendell)
Admin
I don't know if there's a direct connection or just coincidence. Buuuuuut... I used to buy computers with AMD processors almost exclusively. Then one day I purchased an Intel-powered laptop and it just seemed like it was much less buggy in general. But it's really hard to say if it's because of that. I would almost venture to guess that it's more because that the AMD computers I've encountered are usually low end computers and Intel computers tend to be a little bit higher end. So it may not be the processor so much as the overall quality? I dunno, all guesses here but based on my experience.
Posted : January 20, 2014 8:50 pm
 BigE
(@bige)
Well..for general consumption AMD is fine. But they are an Intel knock off imitator (sp?) If you want the "real deal" then get it.
Posted : January 20, 2014 8:57 pm
(@jack-chiles)
Xeon CPUs
are specifically programmed to work in CADD better than regular Intel chips. Not so much for gaming, tho.
Posted : January 20, 2014 9:01 pm
(@the-odolite)
Generally speaking, AMD processors offer a better price/performance ratio than Intel processors. If cost isn't an issue and you need a powerful processor for whatever program you're going to run, buy a more expensive Intel-powered model. If any new laptop will run the program you're going to use, you can save a few bucks by buying one with an AMD processor.
Here's a chart, showing the current common cpus: http://www.cpubenchmark.net/common_cpus.html#cpuvalue
It's more of an issue if you were going to build a desktop for yourself. There's so many different models of laptops and processors, sales coming and going, it's really hard to do a direct comparison between models. You're probably fine with either.
Posted : January 20, 2014 9:23 pm
(@lee-d)
I totally agree with Wendell - the AMD machines I've had experience with have been buggier than Intel machines. I would imagine that it has to do with the bios that they use; I figure that if the software developers are running Intel then that's probably what I should run as well.
Posted : January 21, 2014 6:46 am
