Wendell, is there a way to do a strike-through? There was an older method of putting in front of the text you wanted to have a line through and to turn it off Is there something similar in this html language (if that is what it's called)?
Thanks, Tom
Hmmm... that didn't work
3 attempts - no joy - yet
[code=html]try this
ok. I give up.
this work?
Appears to. In html, or whatever, the special codes are made using the brackets ans a forward slash. To "strike through" use [ s ] to begin amd [ / s ] to end, leaving out the spaces between elements.
Plus to the right of the message pane there is a radio button that says "strike". it does the same thing. Third button from the top. 😉
It's right there in the list of buttons, under the italic button! Didn't you see it there?
Just kidding, I just now added it. Give it a shot! 😀
strikethrough
APRIL FOOLS!
For security reasons, HTML is not allowed. You must use BBCode via the buttons to the right of the posting text box. However, there might be one or two "hidden" BBCodes...
An equation writer would be helpful, since we can't use HTML.
Ralph
[msg=2307]LaTeX Math[/msg]
Thanks I wasn't aware of it.
Ralph
Pretty Cool,
[tex]$$ left[ begin{array}{ c c } 1 & 2 3 & 4 end{array} right] $$[/tex]
Thanks Wendell everyone. cptdent, I thought I had tried brackets instead of that other symbol. I must not have. I hadn't seen the sarcasm button before either.
How cool
[sarcasm]A Damn Surveyor[/sarcasm]
