Working in Oregon
5 Users
Sebastian
(@sebastian)
We have a job in Oregon that we will have to connect to the ORGN network. We are in Washington now so I am familiar and set up to connect to WSRN.
We are working with a CS15/GS14 Leica Smartworx set up.
From what I have gathered so far:
Seems like I just need to create a new server profile with the correct IP address and Port. Then once I am connected up it will automatically find the closest station to use.
Thanks for any info you can provide!
Posted : June 4, 2015 11:40 pm
Zoidberg
(@zoidberg)
I've got a how-to document I can send you if you provide your email. It's written up for NY but its specific to the CS15 controller running SmartWorx so as long as you have the IP and the Port for OR then you should be good.
Posted : June 5, 2015 5:21 am
Norman_Oklahoma
Contact Ken Bays at ODOT. He can help you out. Also, your Leica Dealer, Kuker Rankin, should have the 411 you seek.
Posted : June 5, 2015 6:26 am
Sebastian
(@sebastian)
Thanks so much. It's: sebagarcia001 at gmail dot com
Posted : June 5, 2015 6:43 am
Sebastian
(@sebastian)
That's awesome, thank you the info!
Posted : June 5, 2015 6:44 am
Is Not One US Survey And The Other International Foot SPC?
Just recalling from way way back.
Posted : June 5, 2015 7:21 am
Norman_Oklahoma
Oregon uses the International foot, while Washington uses US Survey Foot. It's a day-to-day, project-by-project issue here in the Portland/Vancouver area.
Also, Sebastian will probably need to acquaint himself with the appropriate Oregon Coordinate Reference System LDP for the area he will be working in, and will likely need to enter it to his systems as a custom zone, as many softwares do not yet incorporate them in their standard lists.
Posted : June 5, 2015 8:23 am
Kevin Samuel
(@kevin-samuel)
Start here...
http://www.oregon.gov/ODOT/HWY/THEORGN/Pages/Theorgn-Home.aspx
ftp://ftp.odot.state.or.us/ORGN/Documents/Getting%20Started%20With%20The%20ORGN.pdf
Posted : June 5, 2015 8:28 am
Sebastian
(@sebastian)
Thank you all for your help. I was able get set up in our parking lot and connect with orgn and get corrections. I will look into the coordinate system this weekend. The Leica has a default system for Oregon north and south. Not sure if that is what I should be using.
And we are aware of the international foot we have to use.
Posted : June 5, 2015 9:53 pm
Sebastian
(@sebastian)
So we had a successful week in Oregon in regards to connecting to the ORGN network. No issues at all. Thanks again for all your help!
Posted : June 13, 2015 11:34 am
