Try downloading WinFlash for Trimble receivers. ?ÿWinFlash is Trimble??s PC software for configuring some of the ??deeper?? settings. You can add frequencies to antenna radios.
You might have to hunt and google a bit for WinFlash but it is online. You also need a serial to usb cable to connect the antenna to your PC.
?ÿ ?ÿ
You will probably need to replace the radio module.
Buy the correct radio module for your R8.
Thanks all for your help
I found 2 radio modules.?ÿ
59400-62 60384-42 Bluetooth 410-430 MHz
https://www.ebay.com/itm/184029057033?&autorefresh=true
and?ÿ
P/N 64235-62 410-430MHz Bluetooth Radio Module
Are they all compatible with my system? and the controller?
thanks again for the help. I really appreciate it.
As others have said, that is likely going to require a new hardware modem, there is a slight chance it is software changeable, check with Trimble to find out for sure.
Why do you need the one you just bought to operate on a different frequency range??ÿ?ÿ
Are you trying to use RTK with another R8 unit that has a radio of the different frequency range you stated?
You probably won't be able to reprogram the R8 to use a different range, i.e. 410-430 Mhz vs. 450-470 Mhz.
@robertusa?ý Because the site, we are on, uses 410-430 MHZ. I will probably have to sell the 450-470mhz and purchase a whole new system.
I thought maybe I can purchase this radio https://www.ebay.com/itm/Trimble-R8-Model-2-Rover-Receiver-410-430MHz-Bluetooth-Radio-Module-P-N-64235-62/233217448821?hash=item364cd7db75:g:JHsAAOSwfTlcgJkn
and change the radio.
