Hi
i work with magnet field software on sokkia GCX2. Yesterday i made a mistake and i enter distance for offset from start point and not from end point of line. I tried find coordinates of start and end point of line in raw data but i was unsuccessful. Where i find them? Start point and end point of line were measured only in offset tool.
Thanks very much for your time and help.
In Magnet Field go to Edit >Raw Data
Just above the stored shot you will see Start_Pt and End_Pt
Also when you export go to Exchange >Raw Data >SurvCE(*.rw5)
Toggle on Export GPS Raw data
You will see the Start_Pt and End_Pt here also
JB,NMDefault,DT12-14-2016,TM05:30:55
MO,AD0,UN2,SF1.0,EC0,EO0.0,AU0
--MAGNET Field Version 4.1 (build 243902)
LS,HR0.000
GPS,PN100_Start_Pt,LA55.450895470,LN37.372124970,EL498.289
--HRMS:0.399, VRMS:0.624, STATUS:FIXED, SATS:16, PDOP:1.778
GPS,PN100_End_Pt,LA55.450898755,LN37.372125084,EL498.289
SP,PN100,N 25641611.491036,E 8645445.190705,EL498.289547,--tree
--OLINE, PT1:100_Start_Pt, PT2:100_End_Pt, ALONG:2.500, ACROSS:0.000, VERT:0.000
Thanks a lot, i found it in edit - raw data.
But one another question. In *.rw5 format is only one coordinates for start point and end point, but i measured more then one point in offset tool. So how to export all start and end points?
My *.rw5 export
JB,NMBB_GRANIAR,DT12-15-2016,TM11:03:31
MO,AD0,UN1,SF1.0,EC0,EO0.0,AU1
--TopSURV Version 7.5
LS,HR0.000
GPS,PN1612151004,LA48.442849814,LN19.080179374,EL453.678
--GS,PN1612151004,N 1227817.776623,E 418606.425969,EL410.232423,--
LS,HR2.000
GPS,PN1612150001,LA48.442844470,LN19.080173646,EL454.178,--KOLIK
--GS,PN1612150001,N 1227819.335750,E 418607.715728,EL408.732398,--KOLIK
--HRMS:0.0016, VRMS:0.0025, STATUS:FIXED, SATS:15, PDOP:1.451
GPS,PN1612150002,LA48.442897883,LN19.080236801,EL454.414,--KOLIK
--GS,PN1612150002,N 1227803.843270,E 418593.622832,EL408.968624,--KOLIK
--HRMS:0.0016, VRMS:0.0025, STATUS:FIXED, SATS:15, PDOP:1.456
GPS,PN1612150003,LA48.443007431,LN19.080367217,EL453.970,--KOLIK
--GS,PN1612150003,N 1227772.081941,E 418564.538339,EL408.525252,--KOLIK
--HRMS:0.0018, VRMS:0.0029, STATUS:FIXED, SATS:15, PDOP:1.453
GPS,PN1612150004,LA48.442923534,LN19.080226674,EL454.686,--DOM
--GS,PN1612150004,N 1227795.788421,E 418595.096638,EL409.240219,--DOM
--HRMS:0.0016, VRMS:0.0025, STATUS:FIXED, SATS:15, PDOP:1.468
GPS,PNStart_Pt,LA48.442926810,LN19.080192915,EL455.363
--GS,PNStart_Pt,N 1227794.266386,E 418601.898802,EL409.917825,--
GPS,PNEnd_Pt,LA48.442931751,LN19.080198549,EL455.304
--GS,PNEnd_Pt,N 1227792.830048,E 418600.637518,EL409.858621,--
--HRMS:0.0016, VRMS:0.0025, STATUS:FIXED, SATS:15, PDOP:1.458
SP,PN1612150005,N 1227791.716697,E 418599.662626,EL409.858621,--DOM
SP,PN1612150006,N 1227785.473670,E 418606.868417,EL410.237480,--DOM
SP,PN1612150007,N 1227780.902834,E 418602.906935,EL410.219862,--DOM
SP,PN1612150008,N 1227776.784895,E 418599.792575,EL410.138184,--DOM
SP,PN1612150009,N 1227773.852802,E 418597.265745,EL410.017241,--DOM
SP,PN1612150010,N 1227783.480478,E 418586.172858,EL409.405580,--DOM
SP,PN1612150011,N 1227789.579697,E 418589.658691,EL409.334797,--DOM
SP,PN1612150012,N 1227790.489761,E 418592.296709,EL409.482360,--DOM
SP,PN1612150013,N 1227780.744403,E 418604.359946,EL410.308110,--DOM
SP,PN1612150014,N 1227753.822269,E 418612.489368,EL410.648670,--DOM
SP,PN1612150015,N 1227764.589074,E 418621.823554,EL410.603880,--DOM
SP,PN1612150016,N 1227769.232988,E 418626.866320,EL410.649907,--DOM
SP,PN1612150017,N 1227775.892746,E 418639.917411,EL410.532971,--DOM
SP,PN1612151001,N 1227571.581091,E 417160.307446,EL366.244068,--DOM
SP,PN1612151002,N 1227562.925542,E 417158.386811,EL366.306402,--DOM
SP,PN1612151003,N 1227555.118123,E 417147.633910,EL366.464822,--DOM
Geextah502, post: 404317, member: 12321 wrote: But one another question. In *.rw5 format is only one coordinates for start point and end point, but i measured more then one point in offset tool. So how to export all start and end points?
Geextah,
There are only one set of Start and End points that can be stored for each offset by line. Appears you may have located several points in that set, by pressing the measure button. But forgot to hit the store button, after each set.
The header of your raw data says "TopSURV Version 7.5", is this correct? You labeled this thread Magnet Field, they are very different versions that are years apart.
