Topcon Hiper V Ante...
Topcon Hiper V Antenna Parameters
5 Users
(@jimmy-cleveland)
I am trying to add a Topcon Hiper V antenna to My Topcon Tools V 8.2.
I have tried downloading and importing the antenna files from NGS for this antenna, but I cannot get Topcon Tools to recognize the antenna, and show it in the antenna list.
I had the same problem when I tried adding my OPUS X90 receivers, and had to manually add them by keying in all of the antenna constants, parameters, etc.
I have tried searching, and cannot find this information on the Topcon Hiper V antennas. Does anyone have this information that they would be willing to share. I do not do much static anymore, and have no interest in upgrading to Topcon Magnet Office at the current time.
Thanks in advance,
Jimmy
Posted : 09/05/2016 5:57 am
 Ring
(@ring)
Our Topcon Tech said to use the Hiper II parameters. These should be in V 8.2 list.
Posted : 09/05/2016 9:36 am
(@jimmy-cleveland)
Thank you. I believe our dealer said that they were very close to the Hiper V units as well.
Posted : 09/05/2016 10:09 am
(@jimmy-cleveland)
Randy Black with Topcon sent me the information below from what I assume is Topcon Magnet Tools. I hope this helps anyone needing this information. A huge Thank You goes out to Randy. He is a great guy, and has helped me numerous times over the years.
Posted : 10/05/2016 3:24 am
(@roadburner)
Thanks for sharing! Looks like they didn't provide the PCV values from the PCV tab. I entered the ones from the HiPer II. Seems to work ok.
Posted : 12/05/2016 2:22 pm
(@jimmy-cleveland)
RoadBurner, post: 371972, member: 6168 wrote: Thanks for sharing! Looks like they didn't provide the PCV values from the PCV tab. I entered the ones from the HiPer II. Seems to work ok.
Sorry, I did receive this a little later from Randy, and forgot to update the thread.
Posted : 12/05/2016 5:03 pm
(@roadburner)
Hey, you're alright! 😉
Thanks again
Posted : 13/05/2016 7:33 am
(@jimmy-cleveland)
RoadBurner, post: 372077, member: 6168 wrote: Hey, you're alright! 😉
Thanks again
Ha! Thanks, I try. Randy gets the credit.
Posted : 13/05/2016 10:32 am
(@aldemar)
Ol?­ Amigo!
Vc tem como mandar imagens dos par?›metros?ÿ do Topcon Hiper SR, assim como vc mandou do Hiper V
Posted : 23/09/2019 5:50 pm
(@jerrys)
Jimmy,
I wonder if you have that working yet??ÿ I found out that with?ÿ TopSURV, the HiPer V rover requires the OAF addition for 3rd party software.?ÿ This was for a customer a few years ago that wanted to run a new HiPer V off his HiPer II as a base.?ÿ The DC software must set the RTK Rover Position Update Rate or you have to have that OAF line added.?ÿ OOPS.?ÿ NOW I SEE THIS IS ABOUT POST PROCESSING SOFTWARE
Posted : 24/09/2019 6:53 am
(@jimmy-cleveland)
@jerrys
Jerry, yes, it was for post processing. It seems to be working fine.
Hope you and the family are doing well.
Posted : 25/09/2019 4:34 am
Share:
