TEQC help
(@daneminceyahoocom)
I wonder if it is possible to edit the attached rinex file in order to improve it OPUS stats.?ÿ when I run QC it reports that G18 is unhealthy. when I remove G18 OPUS reports that I do not have 2 hours of data. ?Also the the QC reports something unknown, the receiver type??ÿ ?ÿAny suggestions on how to remove sats in individual sections for cycle slip I guess. thanks for your help
?ÿ please delete .txt at the end of .19o file. It wouls not upload otherwise thanks for your help?ÿ
Posted : 12/10/2019 8:55 am
I'd run it again next week to get Rapid results instead of Ultra-rapid, just in case more CORS data comes in that helps.
With only 40% of the observations used, I'm not sure you can ever tweak this data set into good results.?ÿ What was the environment, too many trees and/or power pole wires and guy wires?
Posted : 12/10/2019 10:51 am
I dunno Dane...
After looking at the RINEX file, the station location (Google Earth), and the OPUS Report, I suspect that there isn't really much hope.
OPUS used ONLY 40% of the observations (a very bad sign).
The L2 P2 data in the RINEX file is very "hit/miss" (another really bad sign)
The location of the remote station doesn't look very "GPS friendly" to start with.
It is possible (but far from a sure thing), that a more modern GNSS unit (say an iGage IG3s) MIGHT return a cleaner observation file, but probably not. I would suggest a "better" station location, but those look to be few and far between in that area.
Posted : 12/10/2019 11:00 am
