TBC Question- DOES ...
TBC Question- DOES this note mean
5 Users
what it says......
does it make sense?
Posted : May 12, 2015 8:32 am
(@lee-d)
It means what it says. You have three choices:
1) Single Observation: TBC holds one observation and everything else is just used as a comparison - for instance, in a Point Derivation Report (if you're not familiar with this report, you may want to check it out)
2) Weighted Mean of Like Observations: will compute a weighted mean, as it says, of like observations; RTK, total station, etc. RTK, for instance, is weighted by the covariance data of the observations.
3) Weighted Mean of All Observations: Will calculate a weighted mean of all observations to a point, weighting the observation by whatever you have set for Default Standard Errors in your Project Settings.
Posted : May 12, 2015 8:44 am
That's NOT what it says...it says short observations have more weight than long observations
Posted : May 12, 2015 8:50 am
(@lmbrls)
> what it says......
> does it make sense?
Trimble's
Blasted
Confusion
If it is easy, TBC makes it hard.
Posted : May 12, 2015 9:48 am
(@lee-d)
It makes perfect sense that shorter observations would be weighted heavier than longer observations, at least with RTK.
Posted : May 12, 2015 10:36 am
(@lee-d)
Not sure where you see that, this is straight from the Help:
As is this:
Posted : May 12, 2015 10:41 am
My snip is straight from project setting> computations
Posted : May 12, 2015 11:35 am
M'kay - so if I shoot a point as an observed control point for 60 epochs- then later for 600 epochs - the pragr is correct in assigning greater weight to the 60 epoch observations....
Posted : May 12, 2015 11:40 am
(@lee-d)
It would appear that they contradict themselves...
Posted : May 12, 2015 11:42 am
(@lee-d)
I've always understood the weighting to be based on the precision of the measurement, I never even noticed that bit at the bottom of the Computations screen. Obviously, there could be circumstances where a longer shot would have better precisions than a shorter shot.
I don't have any good connections in the TBC group but I'm going to try to get an answer from Trimble on this.
Posted : May 12, 2015 11:47 am
"It makes perfect sense that shorter observations would be weighted heavier than longer observations, at least with RTK."
That doesn't make any sense to me at all. Please elaborate...
Posted : May 12, 2015 11:58 am
Do they mean shorter in time or shorter in distance?
Posted : May 12, 2015 12:01 pm
(@lee-d)
By shorter I meant in distance, not in observation time. All else being equal, the ppm error in an RTK vector is going to make a short vector more precise than a long vector.
By no means did I mean to imply that it would be correct to weight vectors purely on their length.
Posted : May 12, 2015 12:06 pm
(@lee-d)
They would have to mean shorter distance but that still doesn't make sense; I don't want a 3 second shot in the trees weighted heavier than a 20 second shot in the wide open at any reasonable distance.
Posted : May 12, 2015 12:10 pm
Lee D, post: 316999, member: 7971 wrote: I've always understood the weighting to be based on the precision of the measurement, I never even noticed that bit at the bottom of the Computations screen. Obviously, there could be circumstances where a longer shot would have better precisions than a shorter shot.
[USER=7971]@Lee D[/USER] -
did you ever hear from anyone at Trimble on this?
Posted : August 25, 2015 1:14 pm
(@lee-d)
No I'm afraid not but I'll try another inquiry
Posted : August 27, 2015 5:18 am
