TBC Baseline Proces...
TBC Baseline Processing Problem
7 Users
Any thoughts on what might be causing this? I've loaded observations files (obvious, since a vector is acknowledged) and ephemeris files, the antennas are models I've used many times before, yet it won't process. This is a vector that I've been processing weekly for about a month, and this has never happened before. Any ideas?
Posted : July 4, 2015 12:10 pm
(@alan-chyko)
I just experienced the exact same thing, but it my case it happened on a project that I set up differently from the way I normally do. I usually create the project folder & subfolders, download everything using Data Transfer and save them in the project Import folder. For the last project I tried to utilize the Direct Connection dialog in TBC, and I activated the "Copy Data to Import Folder" in the project options. Everything downloaded fine, wound up in the correct Import folder, but nothing would process. I kept getting the same message you did.
The only fix I found was to start over - created a new project, unchecked the "Copy Data to Import Folder" option, saved all the files in the Import folder and imported them using the Import dialog.
Posted : July 5, 2015 5:06 am
(@yuriy-lutsyshyn)
If you could send me your files I would try to process on TBC v2.00
Posted : July 5, 2015 5:08 am
Jim Frame, post: 325809, member: 10 wrote: Any thoughts on what might be causing this? I've loaded observations files (obvious, since a vector is acknowledged) and ephemeris files, the antennas are models I've used many times before, yet it won't process. This is a vector that I've been processing weekly for about a month, and this has never happened before. Any ideas?
My thought would be make sure you have all of the broadcast ephemeris files for the actual times and precise ephemeris files that cover at least a couple of hours either side of your start/stop times. So if you have a 24 hour file from midnight to midnight, make sure you have the precise ephemeris files for the day before and the day after.
Posted : July 5, 2015 5:43 am
I tried starting over with a new project, and that did the trick:
I have no idea what made the difference, but I'm happy that it worked!
In the past I've run into the ephemeris coverage that John mentioned, but that wasn't the case this time -- I only imported the precise ephemeris, and everything processed.
Posted : July 5, 2015 7:46 am
(@scotland)
Maybe missing a file... hidden?
sent unknown location by me
Posted : July 5, 2015 7:55 am
(@kris-morgan)
I've seen that before and the session editor gave me no help as to why. I created new projects and did the same thing and it would work then. A ghost in the machine.
Posted : July 6, 2015 4:11 am
(@renipurma)
what is wrong when i import ephemeris file to my project, why doesn't successesfully. .?
can you help me to solve this problem
Posted : May 4, 2016 8:36 pm
