I've been using the survey pro demo till i save up some money to get an access controller. If i'm not mistaken, you cannot add a functional nrtk network with the Demo version. Correct me if i'm wrong.
So what is my other option? Can i do this with RTKLib, connect to a base transmitting corrections and then connect to my Rover and start storing points, while known on the fly the status of fixed/float precision
I have an extra data collector with Survey Pro Demo on it. I have used it as a network rover. We have a permanent base set-up at the office and use snip as a castor. I this similar to what you are trying to do? I am limited to only 25 points per job, though.
This is exactly what i want to achieve. How did you get to set the network connection on Survey Pro. It does not let me add a network stream, unless i have select the demo equipment, which provides imaginary data..
We already had the network set-up and running on our regular data collector w/surveypro. I just set it up exactly the same in the spare data collector with the Demo version.
I'm the surveyor. My brother is the computer guy. He's the one who got everything set up and working.
Could you please ask your brother to provide information on how to set this up, cause so far i have not been able to figure it out?
