Spectra Precision E...
Spectra Precision EPOCH 35 Receiver
Vinny
(@vinny)
Has anyone experienced the recent failure of the Spectra Precision EPOCH 35 receivers to collect Satellite data. My unit quit about 2 weeks ago. I found a demo unit on line, met salesman to check it out, it acted exactly the same (came on, self-tested OK, no satellites). I sent my unit in to dealer to have firmware updated (as dealer said possibly Kick-Start the unit). While in transit to dealer, dealer emailed that they had just gotten an EPOCH 35 in with the exact same problem, and firmware didn't resurrect it. My unit would always report 12/31/1979 on the OPUS file. I suspect a programming "Date" problem. Three unrelated units recently with same problem.
Posted : August 11, 2017 11:39 am
tacotime
(@tacotime)
Hi I have 3 with the same issue did you ever end up finding a fix for this?
Posted : July 4, 2019 12:33 pm
gto234
(@gto234)
@tacotime
I think you should update the firmware to the latest 3.907 from novatel.
I have a epoch 35 on order from ebay and need some info on radio antenna.
The manual says that the antenna has to be 0db or 5db
Can I buy antenna with 3db like this? Will it work?
I would like also info on MPU firmware update.
Posted : July 31, 2019 1:39 am
gto234
(@gto234)
Hey, anyone using epoch 35 receiver, can you tell me the default pin for bluetooth pairing?
Tried "0000" "1111" "1234" but doesn't pair.
Posted : August 12, 2019 3:34 pm
VIBS
 VIBS
(@vibs)
@gto234
Hi, i have the same problem with a epoch 50. Does anyone know the bluetooth pin or software to access the receiver?
Thank for your help!
Posted : November 16, 2020 8:23 am
gto234
(@gto234)
The epoch 35 (don't know for epoch 50) doesn't pair with android devices that require pin because there is no pin! The only way to pair the epoch is with windows mobile data collectors that doesn't require pin.
BTW the epoch 35 works great up to today. Don't know for the future but for now it works pretty good as GPS-GLO receiver.
Posted : December 28, 2020 11:41 pm
