Hi guys,
Does anybody have a step by step manual for running RTKlib application on a Raspberry pi?
Thanks
Saeid
I am sure that SOMEONE will have this, or similar, eventually, if it's not here now.
You probably have this already, but this link?ÿ http://www.rtklib.com/prog/manual_2.4.2.pdf?ÿ may have what you need. One key item is that RTKLIB is much more complicated under operating systems other than Windows 10.
Good luck.?ÿ
Unfortunately I haven't got the answer yet
Thanks for the reply. I followed the manual of RTKlib but I have difficulty to run the make file in gcc folder (one step before finish). I will be thankful if somebody can help me to do this last step
Hi,
did you hava a look at the Raspberry Pi forums??ÿ
https://www.raspberrypi.org/forums/viewtopic.php?t=202266
If you find a solutaion please post your results back.
Succses,
Christof.
