RTK data connection...
RTK data connection issue with NYSNet
2 Users
(@alexfalli11)
Hello everyone,
I have an interesting issue, I's using a Trimble R8 with with an internal GSM radio (No sim in there). My Collector is a TSC2 with Survey Controller 12.49.
Firstly, I usually connect this with an AT&T Mobile Hotspot over wifi and never have issues with NYSNet. I also have a Local RTK network that i use, works the same way.
Now, I came across a T-Mobile SIM card and decided to put it in the Antenna because want to use the hotspot for something else. When i connect to my Local RTK network via the modem in the antenna, i see all my mountpoints and go to work like nothing has changed.
Here is the issue: When i connect to NYSNet via the modem in the antenna, it calls in and says internet connection is established, but when i start my survey, the system hangs up on the "building source list" step and does nothing else.
I'm baffled because with the same login, ip, and port#, the rover can connect over wifi, but not via bluetooth... HELP?:-S
Posted : April 28, 2014 1:05 pm
(@leegreen)
Sounds like your SIM card is NOT working.
You may be connecting to the network, but the card is NOT authorized to transmit or receive data.
Posted : April 28, 2014 2:46 pm
(@alexfalli11)
Im going today to get the simcard replaced. I hope it does something different. After all, I did get it to work with the Local NTRIP Base Network via the T-mobile Simcard. I am beginning to think that it may be a compatibility issue of some kind between NYSNet and T-moblie? (makes no sense to me) I'll post again after i try the replacement card.
Posted : April 29, 2014 3:09 am
