Punch with centerin...
Punch with centering sleeve
(@tommy-young)
Can someone tell me what and where to get the tool to put the dimple on top of an NGS rod monument?
Posted : May 15, 2014 10:21 am
If you're referring to the round-top stainless bench mark rods, I've always used a regular punch and (gently! -- you don't want to drive the rod down farther) tapped it with a hammer to put a punch mark for holding a GPS tripod or prism pole point. You can also use a slip-on adapter, but I find those to be not worth the trouble.
Posted : May 15, 2014 10:46 am
(@tommy-young)
Ok, I'll try that.
Posted : May 15, 2014 12:13 pm
A good trick is to use plastic rebar caps. They usually fit snugly over the rod, and have a small hole to put the rod in. And they can be removed for precise leveling.
Posted : May 15, 2014 12:26 pm
(@tommy-young)
That right there is why you make the big bucks.
Posted : May 15, 2014 12:34 pm
