Living on an island, I run into this alot.?ÿ As I understand, to generate a solution, the work site must be within a triangle formed by OPUS stations (CORS?)
We have a number of CORS stations but our work sites are not typically within a triangle formed by CORS stations.
Is their a workaround in OPUS I'm not seeing ??ÿ Thanks for your comments in advance.
FILE: 28650141.20o OP1579306255809
?ÿ6029?ÿ?ÿ After the single baseline analysis, fewer than 3 useable
?ÿ6029?ÿ?ÿ reference stations remain. Aborting.
?ÿ6029
Under options you pick CORS sites to use.
UFCORS and PP software. Download and process on your own.?ÿ Years ago i had bad geometry and the nearest CORS was 45 to 60 miles away.?ÿ I had some 8 hour sets that came out ok but not great.?ÿ It was back when MTS gave away static (now Leica network) and I could process through TopCon Tools.?ÿ Then I bought some old sokkias and setup a base on my roof.
OPUS isn't good at giving the most relevant and informative error message.?ÿ I've seen this message when I submitted too soon, before the CORS data had all become available on the NGS computers, so if you do have more CORS in the region it may work later.
I didn't think OPUS-S required the point to be within a triangle of CORS.?ÿ OPUS-RS did originally require it to be within the polygon of CORS, but they relaxed that by 50 km.
THE OBS FILE WAS FROM wED. 1/15. i WAS THINKING 36 HR WOULD BE ENOUGH. THANKS FOR TIP.
That usually would be enough, but it isn't the hours after observation directly that counts. I found it best to wait until about 1 PM eastern time on the day after the Greenwich day of the last observation in the file.
So if you take data after 2 pm on the 15th in Hawaii that's 16th UTC. You have to wait until the end of the 16th UTC plus time for the data to be processed.?ÿ I wouldn't expect all the data to be ready until maybe 7 or 8 am of the 17th in HI. Occasionally later.
That was my suspicion as well.
Loyal?ÿ
