OPUS aborting messa...
OPUS aborting message
(@jerry-attrick)
Gents,
I submitted a 35 minute GPS session to OPUS RS and received the following response:
6029 ?ÿ?ÿAfter the single baseline analysis, fewer than 3 useable
6029 ?ÿ?ÿreference stations remain. Aborting.
6029
Can any of you tell me what that means??ÿThis was an urban canyon site. There are numerous reference stations in the vicinity.?ÿ
I also sent the file to Javad's DPOS service and received a solution about 3 hours after a morning data collection session.
Thanks for your help.
JA, PLS SoCal
Posted : 20/03/2019 7:23 pm
(@david3038)
I always get that message from opus if I send a rapid static in the same day as the session.?ÿ Give it 24hrs.
David
Posted : 21/03/2019 2:51 am
Rather than 24 hours, the magic time for a session that ends before 0000 UTC (USA evening) may be about noon EST on the next day or a little after.
Posted : 21/03/2019 3:16 am
The message is : "After the single baseline analysis, fewer than 3 useable reference stations remain. Aborting."
Most of those available CORS (reference stations) may not have yet been downloaded to the CORS reference bin or more likely have been downloaded and not yet checked out and filtered to be suitable for smooth operation in the RSGPS program that OPUS-RS uses. OPUS-RS requires clean L1, C1/P1, L2 & C2/P2 data. If you have ever checked your own data, you can see that as a satellite becomes visible, the L1 observation can precede the L2 observation and then the first few C1/P1 & C2/P2 observations can be incorrect values until everything is resolved. From time to time I have had to filter out some of those bad observations in my own RINEX files. Also to keep in mind is that OPUS-RS first starts with data well before your observation file and continues past your end time. This gives OPUS-RS a longer time frame to create a very good atmospheric model so your rover site can be resolved in a sorter time frame. The need to create that good atmospheric model is also why OPUS-RS wants your rover to be within the outer perimeter of your reference station polygon. Again, mostly from the past I have files where all the closest CORS were to one side or the other and I could get a better solution by forcing OPUS-RS to use a farther away CORS that enlarged my polygon to surround my rover.
The above message also means because of the poor base information, OPUS-RS has not tried to do anything with your file.
BTW, the L1, C1/P1, L2 & C2/P2 data is the raw calculated distance from the satellite antenna to your rover antenna in meters, and they are different due to the different atmospheric delays due to differing signal wavelengths. Satellites directly over head have the highest angular elevation and the shortest distances.
Posted : 21/03/2019 7:34 am
(@jerry-attrick)
Paul,
Thank you for that information. I am humbled by the depth of your knowledge. I am not of the makeup to get into a topic that deeply. Never studied a RINEX file, never have, probably never will, given my jerryattrick status. You know, old dogs...
Anyway,?ÿI have always been sensitive to the timing of file availability with OPUS over the years. I have an option in the JAVAD service and regularly send data to both just because I can.
This session was early on St. Patrick's Day this year and I have sent the file to OPUS each day since, including today, with the same error. Data should have been available by now, surely. The site is in downtown Los Angeles and the ocean to the Southwest does limit the potential polygons from that direction. Thank you for making that point. It makes perfect sense.?ÿ
Results are very close between the two services. One big difference is that I can get a solution within minutes, once in a while, with JAVAD. The collection in question finished at about 8:00 AM and I had a JAVAD solution before 10:00 AM, the same day. Sent from my iPhone.
Again, Paul, you are the man! Thanks for your input, all of you.
JA, PLS , SoCal
Posted : 21/03/2019 3:18 pm
I see 7 CORS on islands to your West, and 3 that I checked have data available.
I sent you a message.
Posted : 21/03/2019 6:09 pm
Yesterday afternoon. I sent in 5 RSs and 3 Statics that I observed on Wednesday in Susanville. The RSs came back quickly saying they are outside the polygon so be cautious. Then after a while the Statics came back looking really good. Then later in the evening I received two more solutions on one of the RSs without the outside the polygon message (the same one twice so now I have three solutions), that was strange, haven't seen that before.
Posted : 22/03/2019 8:41 am
(@kevinfoshee)
I get the same message for a file from 03-19-2019.?ÿ The data is from a point in a fairly open field. I have about 1.5 hrs of data. It looks like good data to me. I've never had this problem before. I'm very confused?!?!
Posted : 22/03/2019 9:39 am
(@kevinfoshee)
Ok. Got the same message today from a 1.75 hour observation in a pretty ideal location for GPS. I processed the file through Trimble RTX. I got a solution that look good, but, it's 2000 feet to far to the north?!?! What the heck?
Posted : 17/04/2019 7:33 pm
(@kevinfoshee)
I don't know what happened to that last post, so...
I got that same message today for a file that was in pretty ideal conditions for GPS. I processed the file through Trimble RTX; but the solution was 2000' to far to the north.?!? What the heck?
Posted : 17/04/2019 8:23 pm
I learned something this week, OPUS computes 6 baselines and uses the 3 best ones.?ÿ I did not know that.
Posted : 18/04/2019 5:05 am
