NRC PPP
2 Users
larry-scott
(@larry-scott)
I have been using the NRC PPP website, the alternate OPUS.
Q: in the RINEX file for antenna type, is there a doc with antenna model and/or description of record format? And will it use ARP (bottom of antenna at the tribrach) antenna height??ÿ
What I tried to enter was unrecognizable.?ÿ
So is the an example for standard RINEX antenna descriptors??ÿ
Posted : January 7, 2019 11:20 am
igs14.atx contains antenna calibration data.?ÿ It's a bit to wade through, but you can search for antenna name and/or model to expedite the process.?ÿ For example, if you have a Javad Triumph-2, you can search on TRIUMPH and the first hit you get is JAVTRIUMPH_2A, which is the RINEX name for that antenna.
Posted : January 7, 2019 12:37 pm
