Leica Viva GNSS GS ...
Leica Viva GNSS GS 14 programming
2 Users
(@ahmed-nabil)
Hi dears...
i have a new leica viva GPS GS14 and i need to programming it,
any one can help me to setting up the device,
and, what is the requirements i need to setup correctly because i dont have leica geo office (orginal copy).
Regards
Posted : July 30, 2017 12:07 pm
(@john-putnam)
Ahmed,
If you do not have a CS15 then you can program the GS14 via its built in web application through blue tooth. If I recall correctly, the users manual or technical manual have the instructions.
Good luck
Posted : August 8, 2017 12:23 pm
(@ahmed-nabil)
John Putnam, post: 440851, member: 1188 wrote: If you do not have a CS15 then you can program the GS14 via its built in web application through blue tooth. If I recall correctly, the users manual or technical manual have the instructions.
thanks for reply me
i have Cs15 with Gs14
But i think we need also using Leica Geo Office to complete programing the sensor or not ?
also in think the user manual and technical manual just explain how to connect Via Cs and Gs And TPS and how to use it
Regards
Posted : August 14, 2017 5:48 pm
(@john-putnam)
I'm not sure what you mean by programming. The CS15 will control the GS14. You can also use the CS15 to program the GS14 for solo use.
You can use the CS to create codes and coordinate systems. Geoid files need to be created in LGO or Infinity.
Posted : August 23, 2017 12:48 pm
(@ahmed-nabil)
John Putnam, post: 442773, member: 1188 wrote: I'm not sure what you mean by programming. The CS15 will control the GS14. You can also use the CS15 to program the GS14 for solo use.
can you nomerate me the steps for setup new GNSS at first time
because if you bought a new GPS, you must to setting up the GPS to Work correctly in our country
now i have new gps and i need to entring the coord system and type of raido and vertical offsits of base and rover
how cai i do that
regards
Posted : August 26, 2017 2:48 am
