Leica Rover and Tab...
Leica Rover and Tablet compatible with Trimble Business Center?
5 Users
Byron Curtiss
(@byron-curtiss)
A partner my company works with is offering to sell us his iCG60 Leica Rover/ CC80-11Tablet. Is there any issue using this in conjunction with Trimble Business Center? All of the other equipment we use is trimble. I've strictly been a total station guy so I have very little familiarity with GNSS workflow. Any other comments on these Leica units in general?
Thank you
Posted : March 22, 2023 11:56 am
rover83
(@rover83)
Yes, unless you plan on trying to export some commonly recognized format from the receivers and then import to TBC. Even then it will likely be a headache, as a lot of things tend to get lost in translation, especially when exporting from newer gear.
In my opinion it's probably more trouble than it is worth. Stay yellow or green, don't mix and match unless it's absolutely necessary...or you got a screaming deal and don't mind a lot of contortions and extra steps in your workflow.
Dunno about these units, they are construction-side, which I have very little familiarity with. Leica tend to make solidly constructed and very reliable, precise gear. I'm not a huge fan of the field & office software (not super intuitive from my survey/geomatics perspective), but it is still some of the best you can get.
The other question to ask is, do you have good local support for this gear if you choose to buy and use it?
Posted : March 22, 2023 12:55 pm
We mix and match a little data from time to time and I agree with Rover83. It's not bad with static, but I find the antenna modelings errors problematic. That's not helpful on vertical...
Posted : March 22, 2023 1:05 pm
john-putnam
(@john-putnam)
Antenna modeling should not be a problem as long as you get them from the same source, say NGS.  That has been the case for decades when dealing with post processing.
As Rover and Bionic have said, post processing is doable but bringing in RTK data for adjustments may be a headache.
Leica's construction gear uses its own software and may not work that well for a surveyor unless you are mostly doing construction.
Posted : March 22, 2023 10:26 pm
chris-bouffard
(@chris-bouffard)
Leica has a proprietary format for exporting raw data and does not play well with other manufacturers equipment.  I would suggest that you do not mix the two brands or you will find yourself beating your head against the wall.
Posted : March 23, 2023 10:56 am
