How to connect RTKG...
How to connect RTKGPS+ with GNSS receiver Topcon Hyper +
(@geogeek)
I would like to use the andoird app RTKGPS+ as a controller for GNSS receiver Topcon Hyper +, so i've tried to connect using the app but it asks me about PIN code, i've tried PIN code like "0000" "1111" "1234" , none of them works , Any idea or any help about this problem.
Thanks in advance.
Posted : November 12, 2014 10:53 am
(@leegreen)
By default there is no PIN code, security is turned off on the HiPers.
Tell your app, no security.
If your app requires a PIN code, then you will need run btconf.exe from a PC, connect via serial cable to the HiPer, then enable security and set the PIN code.
Lee Green
Posted : November 12, 2014 11:26 am
(@geogeek)
Thanks a lot, i cannot test to disable PIN code right now, but have you tried RTKGPS+ or any Other app as Receiver Controller ? it works for PPP Kinematic mode ?
Posted : November 12, 2014 11:31 am
(@dshearon)
If your device will not allow you to connect without a Bluetooth Pin. You can add a pin to the Hiper via Topcon Receiver Utility. Receiver settings > Bluetooth.
Posted : November 12, 2014 1:48 pm
