HOW MANY OF YOUR TR...
HOW MANY OF YOUR TRACKED SATS ARE USED IN YOUR SOLUTION?
8 Users
(@teddwasright)
12 OUT OF 30 HERE.
IF IM TRACKING THEM WHY ARENT THEY USED IN MY SOLUTION?
Posted : 27/06/2019 12:52 pm
(@warren-smith)
TEDD WAS RIGHT - USING CAPS GRABS YOUR ATTENTION!
Posted : 27/06/2019 1:24 pm
It might help to tell what equipment you are using.
And please turn off the caps lock key.
Posted : 27/06/2019 2:17 pm
(@teddwasright)
SOME THINGS NEVER CHANGE.
SP80 AND SURVEYPRO
AND WHAT DO YOU HAVE AGAINST CAPITALISM BILLY?
Posted : 27/06/2019 2:52 pm
IT'S A CONSPIRACY, TEDD. IN REALITY THERE ARE NO SATELLITES. I MEAN, HAVE YOU EVER ACTUALLY SEEN ONE?
Posted : 27/06/2019 2:56 pm
OMG, HE IS AN ISLAND?ÿ
THAT SHOULD BE A GREAT PLACE FOR VERY LITTLE CANOPY
Posted : 27/06/2019 3:51 pm
(@jkinak)
I'm guessing you are using RTK.
When using RTK: as many as are COMMON WITH THE BASE.
Posted : 27/06/2019 4:27 pm
 jaro
(@jaro)
I have been told the number of satellites you base is sending depends on the type of data compression used in your base radio.
CMR+ will send more satellites than CMR.
CMRx will send more satellites than CMR+
25 khz spacing will send more satellites than 12.5 khz narrowband.
I have heard 12 with CMR+ and I think that was with narrowband. The problem I see is that your base doesn't know which ones the rover can see so if your rover is near an obstruction, it might not receive some of the sats that the base is sending. Your rover may be looking at more than 12 but it may only see 9 or 10 of the ones your base is sending.
I have never tried to verify this. Not sure I could if I tried.
James
Posted : 27/06/2019 11:11 pm
(@jaccen)
That, at least, is the case with RTCM (ie. ver. 2 vs. 3)
http://www.geopp.com/pdf/gppigs06_rtcm_f.pdf
Posted : 28/06/2019 6:38 am
