Epoch 50 PP Log fil...
Epoch 50 PP Log files
2 Users
(@cadtechie)
How can I retrieve post process log files from my Epoch 50 receiver??ÿ The manual says that it can be retrieved with Survey Pro, but I can't seem to find a way to do it.?ÿ Any tips will be greatly appreciated.
Thanks,
-KS
Posted : 12/10/2019 1:26 pm
Thru survey pro connect to the receiver via blue tooth. ?ÿThen go to file management in the file tab- it should look into the head and show you the files ?ÿselect and download. This is off the top of my head and itƒ??s been awhile since I did it. ?ÿThe file management tab may be under the job tab....
Posted : 12/10/2019 2:55 pm
(@cadtechie)
@rankin_file
I can't find the connect to receiver via blue tooth feature in SP.
Posted : 12/10/2019 4:39 pm
@cadtechie
turn your receiver on and start your job.
in the upper right corner of the screen is the selector to change from optical to GPS select gps in your setting open up gnss receivers and pick the correct receiver you want to be connected to-
Posted : 12/10/2019 7:13 pm
