Duplicate Base Poin...
Duplicate Base Point
(@cordgrass)
I did some RTK work around my house and checked it on several benchmarks around town everthing checked ok from datasheets. I was playing around with the TSC2 12.49 trying to learn all of the functions and somehow I created a new base location with WGS coordinates. It is not in the same location as the base 350,000 feet off i am sure this is the WGS84 it is reading. I delete the point but it deletes all of the information for other points. Any ideas i cant find a solution. I assuming download the raw file and delete it then reload.
Posted : May 20, 2017 9:23 am
I think you probably have got your grid zones crossed up.
Posted : May 20, 2017 10:09 am
Agreed, more likely a zone problem than the datum. Or meters versus feet in the zone definition. WGS84 is only a meter or two different form NAD83 in the US.
Posted : May 20, 2017 10:47 am
(@cordgrass)
Is there any way to completely delete the point in the controller or tell it to use the correct basepoint? Both base points are named the same
Posted : May 20, 2017 1:10 pm
