Change in RTN stati...
Change in RTN station coordinates
7 Users
(@squowse)
Hi, I was wondering if you have things like this happen in your area.
There is a new OSTN15 and OSGM15 (shift grid transformation and geoid respectively) for the UK. Previously we have been on OSTN97 and currently on OSTN02.
This is no problem, surveys should state the transformation used and the correct files can be used in order to tie into a previous survey.
http://www.osi.ie/wp-content/uploads/2016/08/OSGM15-and-OSTN15-Updated-transformations-for-UK-and-Ireland.pdf
What is new is that there are new lat/long coordinates issued for the reference stations (CORS). These are starting to be used over the weekend so the Leica Smartnet service will potentially be giving you a different value on next week to the one it gave you last week.
Changes in the CORS coordinagtes are up to 53mm vertically and 34mm horizontally.
http://www.leica-geosystems.co.uk/en/News_19726.htm?id=6757
Trimble's VRSnow have created new mountpoints so you can choose to use the new CORS values. The old mountpoints are planned to be closed at the end of the year which is a bit quick I think.
No word on Topcon's Topnet service. I assume they will be contacting their users privately.
Posted : August 28, 2016 4:48 am
What we have is a New Datum that is not a Datum because you cannot precisely link it to prior datums.
I see no knew corpsecon conversion program, (misspelling intended).
I see no choice on the OPUS page to use prior coordinates, alhough it may have been added over the weekend.
I consider it the death of precise surveying.
Posted : August 28, 2016 5:18 am
 Norm
(@norm)
squowse, post: 388401, member: 7109 wrote: potentially be giving you a different value on next week to the one it gave you last week.
That's how active systems work. Better get used to working that way. This is why it is imperative to set local monuments tied to today's projects for tomorrows transformations.
Posted : August 28, 2016 5:45 am
I just resubmitted an OPUS from 10 days ago, came back NAD_83 (2011) (EPOCH:2010.0000)
I have to assume the minor changes were due to ultra-rapid to rapid orbit variances.
Will check other projects as time goes by.
Posted : August 28, 2016 5:48 am
Paul, OPUS and Corpscon irrelevant to the OP who is in the UK. I think you skimmed his post a little too quickly.
Posted : August 28, 2016 6:20 am
(@squowse)
Paul in PA, post: 388407, member: 236 wrote: What we have is a New Datum that is not a Datum because you cannot precisely link it to prior datums.
Hi this in the UK so it's not OPUS.
Posted : August 28, 2016 7:57 am
Bill93, post: 388411, member: 87 wrote: Paul, OPUS and Corpscon irrelevant to the OP who is in the UK. I think you skimmed his post a little too quickly.
I apologize for flying fast, I thought the topic was xGEOID16A and other upcoming OPUS changes.
Posted : August 28, 2016 12:42 pm
(@base9geodesy)
Get use to it. NGS is currently in the analysis stage of what they reference as REPRO2016 . They haven't released any specifics yet but the three-dimension values for all the stations in the network will likely change. Additionally they have not commented on whether or not they will adjust the passive GPS control to stay consistent with the CORS and how the new values will be labeled. Networks of CORS around the will always be changing from time-to-time. It is the nature of the world we live in.
Posted : August 30, 2016 7:17 am
(@mkennedy)
Transformations are available: GEOCON / GEOCON11. Versions 1.0 have been release, versions 1.1 are in beta.
Posted : August 30, 2016 9:33 am
(@base9geodesy)
GEOCON/GEOCON11 work very well, regrettably NGS has done almost nothing to market these tools to the user community. Not to mention that fact that the input and output formats suck.
Posted : August 30, 2016 10:44 am
(@spmpls)
Don't hold back on us, Dave. Tell us how you really feel!!!
Posted : August 30, 2016 11:02 am
