Floor leveling comp...
Floor leveling compound
11 Users
I come to the source of all knowledge, even though it is far off topic.
I'm supposed to be applying a layer of "self-leveling" (actually self-smoothing and needs help leveling) to the kitchen floor in preparation for vinyl tiles.?ÿ The mixing and coverage instructions don't seem consistent.?ÿ It's Ardex or Henry 549 Feather Finish.
There is approximately a 2.2 : 1 ratio of coverage area between UK and US brochures. Somebody mixed up pounds and kilograms. Which version is right?
A United Kingdom data sheet says
A 11kg bag ... 10m2 at a 1mm thickness. That's 0.91 liters/kg
A 5kg bag will cover 4.5m2 at 1mm thick. That's 0.90 liters/kg
The US version says a 10 lb (4.54 kg) bag covers
33.3 sq. ft. at 1/8ƒ?. That's 600 cu in= 9.83 liters = 2.16 liters/kg
or 3.09 sq. m at 3 mm. That's 2.04 liters/kg
How can a company that's been selling this stuff for years have such discrepancies?
I want to use smaller batches because of its short working time, but I'm not sure how to mix it.
The US mixing instructions say a 10-lb (4.54 kg) bag needs 2.5 quarts (2.4 liters) of water, or to mix smaller batches use 2 parts powder to 1 part water by volume. The UK instructions just say 2 : 1 with no whole-bag data. Do not over-water!
The US numbers imply 5 quarts of powder per bag, but the bag measures out at 3.17 quarts. Using 2.5 quarts per bag is a far different ratio.
You'd think they could be consistent within 10% or so between all the various units.
Anybody have experience with this stuff?
Posted : May 15, 2021 3:43 pm
Posted by: @bill93
The UK coverage numbers imply a cured density of 1.1 times water, which seems low for a cement-based product. The US numbers give a density of 0.49, which I just can't believe.
Posted : May 15, 2021 5:26 pm
@bill93
Might just be a coincident but 0.49 times 2.2 equals 1.1 roughly (1.078).?ÿ Is there a kg/lb. thing going on there?
Posted : May 15, 2021 5:54 pm
Posted by: @paden-cash
?ÿkg/lb
Got to be. Baffles me how that could go on for years.
That factor doesn't explain the difference in bag vs small batch mix instructions, though, as that ratio is about 1.6
Posted : May 15, 2021 6:11 pm
(@richard-imrie)
Some time ago I read a Landrover brochure and in the glossy specification section it referred to the powerplant as a "twin-engine diesel". So, I emailed the contact on the brochure and humbly suggested it may possibly be more correct to say a "twin-turbo diesel engine".
Surprisingly, they replied and said they'd pass it on to HQ who would decide if a correction needed to be made. That got me very excited and it took me a couple of years before I gave up waiting for my services to British automotive industry to be rewarded with a free vehicle.
Posted : May 15, 2021 8:32 pm
Posted by: @richard-imrie
I recently spent about 10 hours doing title research because a title company "didn't have time" to do it after I pointed out a likely defect in the parcel description in one of their title reports.?ÿ They did thank me for doing their work for them, though.?ÿ And I *did* get an invitation to use their research facilities in the future, so there's that.
Posted : May 15, 2021 8:52 pm
(@richard-imrie)
It's possible that they are referring to different types of mix applications.
1mm thick, is well, very thin and may be applicable to a fairing skim coat to be sanded for an even fairer finish. The 3mm thick may be a genuine pourable self leveller.
Anyway, it's fascinating stuff and there are many satisfying videos online. I would humbly and respectfully suggest that mixing and lugging barrels of this stuff is a young persons gig.
Posted : May 15, 2021 10:35 pm
(@flga-2-2-2-2-2-2-2-2)
You actually READ the directions?!!?? Whatƒ??s become of Men.....sigh.... ?????ÿ
Posted : May 16, 2021 4:02 am
Why I gave up directions....
F0DF7915 5BBB 4548 97E7 8544846C2738
Posted : May 16, 2021 7:12 am
There are YouTube videos on how to do EVERYTHING...
Posted : May 16, 2021 7:20 am
(@andy-bruner)
@flga-2-2 As I tell my wife, "If all else fails read the directions".?ÿ She doesn't find that at all humorous.
Andy
Posted : May 16, 2021 7:45 am
@andy-bruner
My wife actually reads and understands the things even without pictures!!! Then tells me which thingys go wherever. ?????ÿ
Posted : May 16, 2021 8:20 am
(@richard-imrie)
@flga-2-2
Years ago in a different lifetime I was doing some casual labour on construction of a commercial building for our family. We were installing a roller door and things weren't going too well so the foreman asked me to get the instructions. I found them in the box, got them out of their plastic bag, and gave them to him. He looked at the cover then screwed them up into a ball and threw them into the trash pile and we carried on without them.
Posted : May 16, 2021 10:52 am
(@richard-imrie)
@flga-2-2
Hey Sir, I've got one of those, and I used it for some time on the tripod of our base station, until the device broke.
Posted : May 16, 2021 10:54 am
I submitted my issues to the company web site and got a response in a few hours (on Sunday) - quite impressive attention.
The answer didn't impress me. It ignored the coverage question, and said the two mixing formulas are equivalent. They claim there are "20 cups" which would be 5 quarts of powder in a 10-lb bag. I agree that would make them equivalent.
But I set milk cartons next to the bag and say no way, not much over 3 quarts. I measured the dimensions of the nearly rectangular bag and compute 3.2 to 3.6 quarts depending on the allowance for rounded corners.
I'll measure very carefully when I use it to see how much is really there.
Posted : May 16, 2021 12:41 pm
@flga-2-2
Here in OK instructions are usually only read while "the paint is drying".
Posted : May 16, 2021 8:55 pm
Jumpinƒ?? Jesus, Bill just dump the bag into a garbage can, fill the bag halfway with water and dump it in also, then mix and dump the whole shebang on the floor and be done with it. We ainƒ??t breaking down Section 36 here. ?????ÿ
Posted : May 17, 2021 6:36 am
(@bstrand)
@richard-imrie
If it happened in the US someone would probably sue them for not getting the missing engine in their landrover.
Posted : May 17, 2021 7:02 am
(@bstrand)
@flga-2-2
Posted : May 17, 2021 7:04 am
@bstrand
Poor Bill, 3 days later and he is in absolute misery trying to figger out how to mix concrete. What could possibly go wrong?.....
956361F7 2F7B 41A5 9388 678E8C41D573
Posted : May 17, 2021 7:17 am
