If you are simply a fact witness, be extra careful.?ÿ If you are a professional expert for one side, contact that attorney.
Posted : November 19, 2018 3:16 pm
The phrase to remember when you get to court when they attempt to elicit testimony:?ÿ I am not prepared to testify to this subject as I am here under a subpoena to produce documents not testimony.?ÿ Then each question, as I was not requested to be prepared to testify as an expert witness, I cannot elicit an opinion on that.?ÿ Even if the question is "according to your map of survey, a double circle is an iron rod; is this double circle with "IRF 1/2" an iron rod found?"?ÿ That is asking you to INTERPRET the map and that is an opinion.
Posted : November 24, 2018 5:55 am
Prev
