Does anyone have experience with the All Small Mentor-Prot??g?? program from the Prot??g?? side??ÿ ?ÿ
We're starting to pull all our 8(a) paperwork together...I know a couple of people who post here work at a large firm that has a couple of joint ventures in place, but I don't really know anyone that works/has worked in one of these joint ventures on the 8(a) side of the equation.?ÿ
not experienced with that particular program but my company benefited greatly as a protege in a 3 year mentor/protege program developed by the Port of Portland.
Best of luck with it! I thought it had a life span of like 8-10yrs that you could hold the 8(a) certification before you were no longer eligible. But I may be thinking of HUB Zone certified... either program are usually required minimum participation percentages for Federally funded projects I believe (I may be off here however). I??m not one but I??ve considered it before. However the amount of work required to market yourself usually is fairly extensive from what I??ve heard?ÿ
