So- The noob needed...
So- The noob needed some help....
They'd just gotten a new high capacity stapler- thru proper purchasing protocols- and the (mis-matched) staples which they loaded/jammed ( it's a breech loader) into it and it wouldn't function/feed AND they couldn't get the staples out and needed some help- so they came over to the old guy for help- suggesting they wanted me to remove to the retaining clip off the pivot pin so we could lift the handle off and take the staples out.- So I answered in my "Archer"voice and said "Do you want parts flying everywhere?!?!?! - 'cause that's how you get parts flying everywhere! they I looked it over for a bit?ÿ and tipped it up and showed them the big spring inside that reset the handle after stapling and explained that between the 2 of us, we didn't have enough hands or joints in our fingers to put it back together if we opened it - and that other than the 2 picture diagram of how to clear a jammed staple- user maintenance or disassembly wasn't really encouraged. Then I reached in my desk and dug out a big paper clip and the mini-tool, drew on my body of knowledge from days of old when we used to lace all the field notes together with cotton twine for submittal with the final pay estimate-?ÿ and fashioned the hook?ÿ & removed the staples..... #OldGuysRule #MakeDoOrDoWithout #oldSchoolMultitool
IMG pc
Posted : March 15, 2019 3:30 pm
GaryG
(@gary_g)
The power of a paper clip!!!!! The look on peoples faces when i say "give me a paper clip"!!
Posted : March 16, 2019 4:10 am
(@flga-2-2-2-2-2-2-2-2)
If you don't have a paper clip, one large and one small, you'd never be able to push the goddamn"RESET" button on practically everything you own. ?????ÿ
Posted : March 16, 2019 4:18 am
Had this been 1965, you could have turned to the secretary and said: "Hey doll, got a spare bobby pin?"
Posted : March 16, 2019 5:02 am
(@alan-roberts)
My standard reply when presented with a situation like you described after a fix of something with a paper clip, cost hanger or scrap of wire is " I'm not an engineer but I did go to an engineering school ".?ÿ That usually elicits a side eye look from others.
Posted : March 16, 2019 6:45 am
Bobby pins are still around, but that form of address would get you into deep trouble now.
Posted : March 16, 2019 10:55 am
