TSC3 won't charge.
(@skeeter1996)
Just was bragging about the lack of problems with my TSC3 Data Collector and now the charger won't charge it's battery. Anyone have a similar problem with charging it's battery? I'm getting desperate now since my battery is below 20%.
Posted : October 20, 2017 5:26 pm
(@norm-larson)
It is usually because the port assembly needs replacement. I just replaced one today. The lack of being able to charge usually accompanies a disconnect in upload download as well
Posted : October 20, 2017 7:05 pm
(@skeeter1996)
It uploads and downloads fine. There just doesn't seem to be a connection between the charger and the battery. The plug-in looks a little hokey, but what could go wrong with that? There's no indicator light on the charger so you can't tell if it's on or off.
Posted : October 21, 2017 7:50 am
(@norm-larson)
More than likely changing the ports will fix the issue, always has for me. They make them as hard to user service as they can, the batteries have a hand shake to identify positive and negative and the ports are all embedded in silicone.
Posted : October 21, 2017 10:03 am
(@skeeter1996)
i was exploring the battery case ad removed the battery. Now it tells me to reset the clock. Where do I find that routine?
Posted : October 21, 2017 12:51 pm
(@skeeter1996)
Got a new charger today. My problem was a bad charger. New charger has me back up and running.
My motto is "Allways at the mercy of a Battery"
Posted : October 24, 2017 8:33 am
Skeeter1996, post: 452286, member: 9224 wrote: Got a new charger today. My problem was a bad charger.
Sorry I didn't see your post sooner. That would have been my suggestion. I just had to replace the power adaptor for my laptop. Same deal.
Posted : October 24, 2017 3:10 pm
