TSC w/ Trimble Access
(@prmixx27)
Is anyone familiar w/ a point to line inverse function in Trimble Access?? I've not been able to find such a function.
Posted : September 3, 2014 2:41 am
(@ralph-perez)
You might want to look in the Cogo menu but it's not straight forward, I recall doing one once. You go into cogo and then scroll down to calculator. In calculator at the bottom you'll see distance. once in distance you have a pull down menu and in there you'll find compute a distance.
Watch this:
Compute distances in Access
Posted : September 3, 2014 2:47 am
(@prmixx27)
I've looked through the cogo menu & have been going through the manual. Have not found it yet.
Posted : September 3, 2014 2:49 am
(@ralph-perez)
See above, I've edited it to include instructions
Posted : September 3, 2014 2:53 am
(@mapman)
Excellent how-to video. Thanks for that. I probably never would have found it otherwise. 🙂
Posted : September 3, 2014 6:46 am
(@squowse)
Thanks I have looked for this before and never found it.
I wonder why it isn't in the normal cogo menu.
I have never used the calculator as I don't like (never used) RPN calculators.
Posted : September 3, 2014 7:27 am
(@makerofmaps)
Took me forever to find that function when we upgraded to access. Seems like it was under cogo on the old version. I wish it would deal with deflection angles as a stakeout or display. All the plans I deal with use deflection angles... Oh how I miss the old SMI 48 Construction 5.
Posted : September 3, 2014 8:39 am
(@lee-d)
You don't have to use the calculator in Access in RPN mode; go into the calculator options and turn RPN off.
Posted : September 3, 2014 11:42 am
(@prmixx27)
Thank you very much!!!! Wow. They sure did a good job of hiding that.
Posted : September 3, 2014 2:10 pm
(@squowse)
Thanks Lee - that makes sense!
Posted : September 6, 2014 7:16 am
