Trimble access vs survey pro
Good morning every one
I used survey pro from 2008 but now I switched to Trimble access
I have question if any one help me I really apricots
When I am using total station with survey pro when I setup station they have option
That remote elevation that I can shoot elevation from total station and saved to
Occupied point and I set up backside
I want to know is their same command in Trimble access I can shoot the elevation remotely and save to instrument occupied point.
Do a station setup as normal, then go to Measure/Station Elevation. The point you want to shoot has to be stored, then take the shot and store it.?ÿ
Yep, that point doesn??t even need E,N, Elevation only will do.
chr.
Thank's buddy its helpful thanks again
Thank's it's very helpful i appreciate
Hi, I am interesting in buying a mechanical total station, and I am between the Trimble C5 and the Nikon FX wich have the same technical specifications, in fact they are the same machine, except for the software, the Trimble uses the Access and the Nikon uses the Survey Pro, and the difference in price is about $700. So my question is: Wich software is better? Is it worth the price difference??ÿ
