Trimble Access continues to surprise me, new glitch
1 Users
(@350rocketmike)
See attached pictures. One of my as staked points was way behind the lot, which I didn't notice until doing the notes. The gnss check was in the correct spot (using integrated mode). Looks like the incorrect shot happened earlier during a rebacksight after the robot went off level (frost and wet conditions). I hadn't stored anything other than the USF (grade) shot but it sure thinks I did.
The only reason it's a big problem is that Trimble refused to fix the issue where a previously as staked point name will not warn you that it already exists.
They say they can't do it because it would add a button press to someone elses work flow, where they keep storing something in the same spot, which is kind of laughable to me, considering how many extra button presses I got from switching to Trimble.
Sorry, grumpy guy doing layout. Rant over.
20230321 142712
20230321 143243
20230321 142722
20230321 142322
20230321 142314
20230321 142710
Posted : March 21, 2023 11:10 am
