Texas Reciprocal RPLS Amended rules
1 Users
 RPLS
(@mike-davis)
I just happened upon this on the board's website:
ADMENDED RULE 661.41 WAS EFFECTIVE AUGUST 10, 2011. Applicant applying under these sections will be required to complete two sample survey reports (sketch, map or plat), completed under the direction of a Registered Professional Land Surveyor. Submissions should be paper copies and also digital copies on CD, DVD, or USB accessible medium. Each survey report should be on a single piece of paper not to exceed 24” x 36”. The digital copy should be in .pdf or similar format. Each survey report should include a certification and a list of all documents reviewed in preparation of the survey. However, a signature and seal are not necessary. One survey should be an urban type survey (residential or commercial platted property) with the other being a rural type survey (metes and bounds). Each report will be evaluated for compliance with the existing Act and Rules. (See the rule in its entirety in the Rules Section 661.41.)
http://info.sos.state.tx.us/pls/pub/readtac$ext.TacPage?sl=R&app=9&p_dir=&p_rloc=&p_tloc=&p_ploc=&pg=1&p_tac=&ti=22&pt=29&ch=661&rl=41
Posted : 07/02/2012 8:15 am
