Field crew flipped their Foresight and Backsight while collecting topo.
How do you change the occupation in TBC?
All we need to do is change FS from 2 to 1 and BS from 1 to 2.
I am not certain that can be done in TBC. If you download with Data Transfer you should also get the *.DC file. I am pretty sure you will be able to complete your edit in DC Editor and then import the edited DC file into TBC.
This is hard to explain, but...
Save the project.
Go down to the bottom of the project Explorer.
Expand the imported Job/DC file.
Find the setup with the swapped oc/bc.
Open the properties of each.
Change the point number of each to the correct one.
Recompute the project (F4).
I am not anywhere near my computer, so I am going off memory. There could be a few more intricacies, but hopefully not... I've given you the basic steps.
Edit: forgot the most important step.
Good advice so far.
One other method is to open a new "optical spreadsheet" and change the setup there.
Could you do it in CAD? Seems like you could grab all the affected points and do a "move-rotate" and be done.
