TBC Antenna Models
(@matthew-m-filus)
I did a bit of searching on the Web and specifically Trimble reference materials and could not easily find how to add antenna models to TBC. Can anyone point me in the right direction? I want to use static data from a Promark 3 with NAP100 external antenna.
Thanks in advance,
Matt
Posted : September 27, 2011 6:49 pm
(@azgpstravist)
Prior to version 2.5 you have to modify the existing antenna.ini file. This is a bit of a pain and you will lose your changes when upgrading so remember to store a backup in a different directory. Version 2.5 and newer allows you the option of creating a custom antenna.ini that is not affected when upgrading. Below is a link to old TGO pdf that will walk you through modifying the existing antenna.ini. I am also working on a quick process guide for creating a custom antenna.ini but that's not quite ready.
Hope this helps!
ftp://www.azgps.net/Software/Trimble/TBC/Adding%20Antennas%20to%20the%20TGO%20INI%20file.pdf
Travis
AZGPS
Posted : September 30, 2011 12:16 pm
(@enmanuelrp)
Hi.-
I'm in the same situation that Matthew M Filus and the link isn't longer available. I'm working with a Geomax Zenith 20, and I really need some help please.
Posted : February 16, 2015 7:55 am
