Surveyors Certificate
21 Users
(@eapls2708)
> To reject this type of certificate, you need only have your liability insurer provide an opinion letter, they won't insure against this type of total liability.
Great advice. Thanks, Richard.
Posted : November 20, 2010 5:21 pm
On the Other Hand, Bryan
> When we created our corporation, the lawyer said if I did not sign off on all correspondence a specific way, people can theoretically sue you personally because you did not properly follow some protocol on the signoff since it would legally imply that the corporate shield was penetrated.
Bryan, I assume that he revealed the secret that if you sign with the other hand than that you normally write with, then it relieves you of all potential liability. Not many surveyors are aware of this.
Posted : November 20, 2010 8:08 pm
Hey thanks for the tip buddy! :good:
Posted : November 20, 2010 8:14 pm
No problem. Just be sure not to do anything that will cancel out the opposite-hand signature, though, such as applying your professional seal right-side up.
Posted : November 20, 2010 8:20 pm
Richard seems to be confused...
an ACSM/ALTA Land Title "Survey" is not a "Survey" product, it is a transfer of liability product. If Richard understood this then he would see that, of course, the Land Liabilator (formerly known as the Land Surveyor) has to sign whatever certificate the lender wants even if it requires the certification that Martians will not invade at this location.
Posted : November 20, 2010 9:05 pm
Page 3 / 3
