I just did a search and noticed that I haven't had an issue for about 8 months, but I noticed something the last couple of times out that don't seem right.
Set up the gun, get oriented, shoot in some irons. When I'm shooting in the points, I'm using the standard sideshot menu in TDS; i.e. not tracking. Shoot the corners using pt #'s 10-20-30 etc. Jump to the inverse screen to make sure everything is jiving and nothing strange is going on. Everything is peachy. Go to start shooting the improvements (curb, driveway, sidewalk, etc.) starting w/ pt# 1000. Last time when I tore down to go to the next setup for some reason all the shots below 1000 were gone. Same thing this time, but at least I checked first. Anybody see this issue before?
Ours tends to forget radio settings but to my knowledge points do not disappear. Have you tried exporting the point file to a computer and seeing if those points are there?
Transfer and delete any jobs that you are not using. I only keep 2 or 3 in my DC.
Back up your jobs in the DC and try a cold boot by holding the on button down for a few seconds.
If that doesn't work reload the latest version of the firmware.
Jim
Interesting. I usually keep 2-3 in there myself, but I've been lazy lately and haven't cleaned it out in a while. I'll give it a shot.
Seems like it is easy enough to see what the heck is going on in the raw data file. I bet there are even some people on this message board who will go through the data file for you if you are stumped.
Make sure Raw Data is turned on otherwise it doesnt store points and you wont be able to inverse between or set up and or backsight to them
I have TDS Foresight DXM. I would be happy to take a quick look at your raw data and job file if you like. The email address in my profile is good.
Jimmy
