Survey Pro and Hydrolite by Seafloor Systems
5 Users
(@frank-willis)
Noble Member Registered
Has anyone found a way to use Survey Pro on a Ranger 7 or a TSC3 with the Hydrolite depth sounder by Seafloor Systems.
Will Hydrolite accept the bluetooth NMEA string and apply depth inside Hydrolite?
Posted : 05/02/2020 3:45 am
(@richard-imrie)
Wouldn't it be the other way around, i.e. the Hydrolite (black-box sonar) sends NMEA depth via BT to the Ranger 7 and hence to Survey Pro?
Posted : 05/02/2020 3:12 pm
(@antcrook)
Reputable Member Customer
I don't think the Hydrolite is compatible with Survey Pro. I am able to get it to work with Topcon Magnet Field.
Posted : 05/02/2020 9:37 pm
(@frank-willis)
Thanks
Posted : 09/02/2020 3:50 am
Famed Member Customer
@antcrook
The connections and data format seem typical. Is this a Surveypro issue?
Posted : 09/02/2020 7:50 pm
(@antcrook)
@thebionicman
I am not familiar with Survey Pro, but I remember reading it somewhere on the Sonarmite website that it was not compatible.  It seems these days that most software vendors have added the option to add a peripheral device when using GPS.
Posted : 10/02/2020 10:08 am
(@frank-willis)
@antcrook
I found out that it is not compatible.  It will output but not receive output from the Hydrolite.  Carlson is, and they run on it, but I can't get GSM to GSM for RTK using Survey Pro latest version on my machines.
Posted : 10/02/2020 11:54 am
(@frank-willis)
Sea Floor Systems confirmed that it does not work with Survey Pro directly and recommended something like Trimble Access
Posted : 11/02/2020 4:34 am
(@paul-d)
Honorable Member Registered
Just an off topic FYI if anyone is thinking of purchasing a Seafloor boat, though named Seafloor, actually using it in salt water will require you to make upgrades to the sealant and other components for it to work properly/long term. Other than that, works great.
Posted : 11/02/2020 9:54 am
Share:
