Hi,
does anyone knows if SurvCE works on a data collector with 240x240 screen resolution instead of the standard 320x240?
I don't see any reason why not, but keep in mind that running the software on a smaller screen will have its limitations. I think the common 240 x 320 screens are small enough, suitable for the field. I'd recommend running on color sunlight readable screen as well. I didn't like running SurvCE on a B&W screen.
What are you trying to do?
Al
http://www.carlsonsw.com/products/data-collection/survce/
EXCERPT:
Recommended System Requirements For Carlson SurvCE, Version 2.0X
Operating System: Windows ® CE 3.0 and higher
Compatible with Windows Mobile 5.0
RAM: 64 MB
Disk Space: 32 MB (64 MB recommended)
Processor: 200 Mhz or greater (Strong Arm, X Scale)
Connections: 9-pin TS232 or Bluetooth (Socket Communications recommended)
Supported Data Collectors
Supported Instrument Default Settings
Carlson SurvCE supports all major manufacturers’ conventional and robotic total stations and RTK GPS systems. These include:
Carlson Surveyor / Surveyor+
CarlsonMINI
Explorer
Topcon Positioning
Juniper Systems
Thanks for the reply,
I was looking for a PDA to have as alternative in case my Getac breaks.
The one I was looking has 240x240 screen.
Eventually I got another with 640x480 screen.
The problem I have with this one is that it cannot connect to the GPS via bluetooth.
It says "The connection failed or the passcode is incorrect" when trying to pair the SOkkia GSR2700isx. It connects fine with the GSR1700CSX and other devices but with the 2700isx has problem. Of course the passcode is correct (0000) so something different is the problem.
Any solutions?
How do you like the sokkia GSR1700 system?
I am thinking of purchasing a system.
thanks
