Surface Pro 4 & Trimble 4000SSi
1 Users
I recently acquired a Surface Pro 4 for use on a job that's going to require me to download a bunch of receivers at various sites. Many of those receivers are 4000SSi models, and I was taking a gamble on being able to make a 2016 computer talk to a 1990s-era receiver.
The Surface Pro doesn't have a serial port, so I bought a USB adapter cable with the FTDI chipset, installed the current version of Trimble Data Transfer, and gave it a go. It took me a few tries to get everything set up right -- I had to set the baud rate for the port using Device Manager as well as specifying it in Data Transfer -- but once I did it connected and downloaded without a hitch. Woohoo!
Posted : March 28, 2016 4:38 pm
gschrock, post: 364479, member: 556 wrote: which model of USB-to-serial device are you using for your Surface?
It's a Ugreen I got from http://www.amazon.com/Converter-Adapter-Chipset-Driverless-Compatible/dp/B00QUZY4L0?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00&apos ;">Amazon for 10 bucks.
Posted : March 28, 2016 5:16 pm
