I recently got a new laptop with Windows 8 on it, and that is ok, however, I would like to start bringing my old laptop into the field.
I need to find a program that can convert a TDS .cr5 file, downloaded with the old TDS transfer file program, with the end result being a .dxf file that I can open with autocad in the field.
I have LT 2002 and XP office, yeah I know, but it still works fine for me.
Thanks in advance.
What's the format of the .cr5 file?
O.K. - Forget the above - should have Googled first!
The file is a text file in PNEZD format with additional columns.
If you open it in Excell and reduce the columns to the first 5 plus any String code column it can be read by FreeCOGO.
FreeCOGO can then export a DXF file that can be read by LT-2000.
Download FreeCOGO here:-
https://dl.dropboxusercontent.com/u/3449356/FreeCOGO_Quadrant.zip
If you like send the file to me and I will return a DXF.
btgraham(at)tpg(dot)com(dot)au
At the risk of self-promotion, Carlson Survey would/should be able to accomplish this for you. With the CR5 file on your computer, the process in Carlson would be to:
1. Issue the Points -- Convert Point Format -- Convert TDS CR5 to CRD.
2. Issue the Survey -- Draw Field to Finish command to process the points in the new CRD into point/linework entities inside the IntelliCAD engine.
3. As a potential alternative to Steps 1 and 2 above, you might even explore the Points -- Import Text/ASCII File command which should be able to handle the process in a single command:
4. From the Settings menu, choose IntelliCAD Options and set the default "Save As" format to the AutoCAD 2000 DWG format (or DXF if you want to go that route):
5. Save the resulting drawing and work to your heart's content in AutoCAD 2002.
^^^^^^^^^^^^^^What he said!! ^^^^^^^^^^^^^^^
Hey..didn't Eagle Point do that too. 😉
I think I found what I was looking for.
http://www.ransen.com/Pointor/Convert-CR5-file-to-Dxf-file.htm
