short prism pole
5 Users
1man Surveyor
(@1man-surveyor)
Does anyone know of a prism pole with a minimum height of less than 4 feet that can extend to at least 10'?
TIA
Posted : March 4, 2015 11:37 am
jimmy-cleveland
(@jimmy-cleveland)
I have seen a few mini stake out poles that are about 1' that extend to about 2'. I have a 1' sokkia mini stakeout pole that I have a 1' and 2' extension that I screw on them as needed.
Posted : March 4, 2015 12:06 pm
Dan Patterson
(@dan-patterson)
Not the exact range you're looking for, but I remember we had one where the minimum height was about 2.7' and I believe the max was roughly twice that or 5.3' or so.
You're describing a three or four sectioned short pole. I don't think I've ever seen one.
Posted : March 4, 2015 1:49 pm
3 Section Short Prism Pole, 2.7' to 5.1'
Most of the time there is a 2' section between the rod and the rod point. It screws off easily when I need to set up a low sight. Without the 2' section attached it carries very nicely in a stakeout bag.
Posted : March 4, 2015 4:49 pm
leegreen
(@leegreen)
I work solo most of the time with robot, and I carry SECO Sliding Prism and Sectional Pole Kit along with my standard prism pole with bipod. The Sliding pole kit has 4-1ft sections of poles, and a mini prism that slides from 0.2' to 4.0'. My prism pole goes from 4.65' to 8.25'. The bags just 14" longs, and goes over your shoulder. So it works well for me. I use it a lot for anchor bolts. It has a 5/8" adapter to mount on a pole or in a tribrach.
Posted : March 4, 2015 6:06 pm
