RTX-PP
2 Users
I've been using it some, it really does work, there is barely any difference between it and CORS/OPUS, mainly in the elevation, it actually is closer to NAVD88, from the few I've done, haven't used it much however.
What are others seeing that use it
Posted : December 10, 2015 1:31 pm
(@lee-d)
Seeing the same results - horizontal is usually right there with OPUS, vertical might be different by 0.10' give or take. They seem to do a little better with 2 - 3 hour files than OPUS; I see better results with OPUS when we go at least four.
Posted : December 10, 2015 1:36 pm
Its a very hands off process, kinda makes me nervous
Posted : December 10, 2015 2:18 pm
(@lee-d)
I agree, they don't tell you anything about how they're doing it and they don't give you a whole lot of information about the solution. But I've ran enough of them on data that was also processed through OPUS and using CORS data in TBC to have a decent feel for it; I wouldn't have a problem with using it if for whatever reason it was the only thing available.
Posted : December 11, 2015 5:54 am
I walked a client of mine through it (not that there's much to do) and he was so excited,,,,,,,,,,,
I don't think OPUS is in his future, all he has to do is download the base, sit for a minute or two and it's over..........
His comment was, this is so simple why should I spend the time with OPUS.....
I have to say however, there isn't much of anything xy between CORS and RTX, I've been seeing it in the verticals, and trimble matches NAVD88 better......so far........
But I have a small sample at this point.
Posted : December 11, 2015 6:16 am
(@lee-d)
I definitely get different results in the V between OPUS, CORS (TBC), and RTX-PP. With our subsidence issues here there really is no good NAVD88 monumentation, so it's usually just a judgement call as to which one to use.
Posted : December 11, 2015 6:24 am
I have a more stable bench situation, I'm seeing the trimble solution closer to the bench's here. But my sample is way too small to give any kinda recommendation.
Posted : December 11, 2015 7:06 am
